guava83
May 21, 2024Follower
MR6500 - Randomly powers off when in no battery mode.
After using the nighthawk MR6500 for home internet for a while, I've noticed a problem. When I switch to max performance mode and remove the battery, the device powers on and functions but will random...
May 21, 2024Guru - Experienced User
Try a different charger and cable. If the charger isn't putting out enough power or the cable isn't rated to it, when it tries to pull that power in max mode, its might be limiting it or causing it to power off.
