sonny_ibby
Jun 11, 2024Aspirant
MR6500-1TLAUS Missing Reboot /Restart icon.
Hi everyone, wondering if anyone here using Telstra Nighthawk M60 Pro with firmware NTGX65_12.01.41.00_00 is missing the "Reboot/Restart" functionality ? Had and OTA update last year from NTGX...
adolfobarton
Dec 25, 2024Initiate
The MR6500-1TLAUS, also known as the Netgear Nighthawk M6 Pro, has been reported to have a missing reboot or restart icon, particularly when operating on USB-C power without the battery installed.
This issue has been addressed in firmware update NTGX65_12.01.53.00, which restores the missing reboot button under these conditions.
To resolve this problem, it's recommended to update your device's firmware to the latest version.
If the reboot icon remains missing after the update, you can perform a factory reset as an alternative method to reboot the device.
Here is the process to reset the device:
From the home screen, select Settings.
Select Options.
Select Factory Reset.
Select Reset Now.
Select Continue.
- jacengDec 25, 2024Tutor
This is great to hear the issue was acknowledged and the reboot option will be put back. I currently have NTGx65_12.01.48.00 firmware. I checked for updates and it says current software is up to date. Because this is associated with ATT network, I am at the mercy of them making that firmware version available for their customers.
Has anybody with ATT branded M6 Pro out there received the NTGX65_12.01.53.00 firmware update yet?
