kha4044
Jul 26, 2024Aspirant
MR6500 5G N77 and N78 coverage 5G network coverage in Saudi Arabia?
Hi everyone! Saudi telecom companies have just started offering 5G coverage. I have already purchased an unlocked MR6500 according to the specifications on the Netgear website, it will work on N77 a...
totorotenten
Jul 26, 2024Tutor
Hi kha4044,
According to this KB:
https://kb.netgear.com/000065647/Which-countries-can-my-NETGEAR-M6-or-M6-Pro-roam-in
I think the best fit for you is maybe the one with the SKU MR6450-100EUS (Europe & Middle East unlocked)
You can provide your SKU product so that everyone can help easier (it’s behind of the hotspot, take out the battery and you will see)
In my opinion, you should register your M6 on Netgear website and then contact with Netgear support about your case to get help from Netgear expert. Hope that your problem will be solved soon.
- kha4044Jul 26, 2024AspirantSKU : 6238D
MR6500-1A1NAS- totorotentenJul 26, 2024Tutor
Take a look on this article to find out more info about your hardware hotspot, I’m afraid it’s not an unlocked version
