Beachguy235's avatar
Beachguy235
Follower
Apr 26, 2023
Mr6500 firmware update?
Good evening, I have an mr6500 nighthawk m6 pro. I am having mobile service connection issues and believe that my firmware may be out of date. How do I go about updating the firmware? Current version is ntgx65_10.01.31.01 with an update date of 4/16/2022. Can anyone help? Thank you
  • Having the same issues and also when i select 6E doesnt broadcast this wifi. I have a lenovo p11 pro with certified 6E network....How to enable on Nighthawk this option? i select on touch screen only 6e but nothing happens.
    Current version of firmware is NTG65-10.01.47.00
    Is any one with similar issues?
    • JT240Z's avatar
      JT240Z
      Luminary
      Seems you're at the mercy of AT&T to push the updates.  I'm in the same boat with an older version that the device says is "up to date".
