Chef42974
Nov 02, 2022Initiate
MR6500 Keeps crashing with Firstnet
Hello all, We switched our service to Firstnet a couple of months ago, and with that, we also upgraded to the NG MR6500 Hotspot. Ever since we have had nothing but problems. The 6500 crashes on a d...
Dustoff77
Dec 02, 2022Aspirant
I’m also having this same issue. On second replacement with no luck. Device seems to overheat, screen flashes and locks up. This is unacceptable for a device costing what it does.
JohnPeng
Dec 02, 2022NETGEAR Expert
The fixes for these issues can be released some time next week if everything goes well with AT&T testing.
Sorry for the inconvenience and thanks for your patience.
Thanks
- Dustoff77Dec 02, 2022AspirantThank you for the update! We’ve been on the phone with AT&T, Firstnet, and netgear and they didn’t have any solutions. Looking forward to the update so we aren’t using phone data for work!
- ihodlbtcDec 02, 2022Aspirant
The FirstNet customer service gave me the run around and told me to place a fan next to the Netgear device (lol). He said you aren't supposed to use it as a home router (which I am not).
My router shuts off after anywhere between 5 minutes, to a few hours and I have to restart it repeatedly.
- NICEGUYNICKDec 03, 2022AspirantNot using as a router at all it hooked on Ethernet switch which ny nighthawk router is plugged in.
