Chef42974
Nov 02, 2022Initiate
MR6500 Keeps crashing with Firstnet
Hello all, We switched our service to Firstnet a couple of months ago, and with that, we also upgraded to the NG MR6500 Hotspot. Ever since we have had nothing but problems. The 6500 crashes on a d...
ihodlbtc
Dec 03, 2022Aspirant
The FirstNet customer service gave me the run around and told me to place a fan next to the Netgear device (lol). He said you aren't supposed to use it as a home router (which I am not).
My router shuts off after anywhere between 5 minutes, to a few hours and I have to restart it repeatedly.
NICEGUYNICK
Not using as a router at all it hooked on Ethernet switch which ny nighthawk router is plugged in.
- NICEGUYNICKDec 03, 2022AspirantIt’s not getting hot either it’s not even finding any networks at all now even after factory reboot the device is trashed I think. It’s not even a month old
- JohnPengDec 04, 2022NETGEAR Expert
NICEGUYNICK wrote:
It’s not getting hot either it’s not even finding any networks at all now even after factory reboot the device is trashed I think. It’s not even a month oldPlease capture a model.json file and send PM to me.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
- JohnPengDec 06, 2022NETGEAR Expert
AT&T has approved the release to fix the reported issues on the data disconnection and Firstnet related. The OTA update has been posted on the AT&T server. You can do a manual upgrade to check to have your device updated. It may take a few days for the devices to find the update.
Thanks
