Chef42974
Nov 02, 2022Initiate
MR6500 Keeps crashing with Firstnet
Hello all, We switched our service to Firstnet a couple of months ago, and with that, we also upgraded to the NG MR6500 Hotspot. Ever since we have had nothing but problems. The 6500 crashes on a d...
NICEGUYNICK
Dec 03, 2022Aspirant
It’s not getting hot either it’s not even finding any networks at all now even after factory reboot the device is trashed I think. It’s not even a month old
JohnPeng
Dec 04, 2022NETGEAR Expert
Please capture a model.json file and send PM to me.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
- JohnPengDec 06, 2022NETGEAR Expert
AT&T has approved the release to fix the reported issues on the data disconnection and Firstnet related. The OTA update has been posted on the AT&T server. You can do a manual upgrade to check to have your device updated. It may take a few days for the devices to find the update.
Thanks
- stir_subtractJan 09, 2023Aspirant
Is there a way to make the device force a firmware update? My firmware is still NTGX65_10.01.31.01 (build date 4/16/2022). It has been turned on and connected every day for the past 2 weeks.
- JohnPengJan 10, 2023NETGEAR Expert
Please send me a model.json log via PM. I will check on this for you.
- Capture the results (by selecting all + copy) and send it back - ihodlbtcJan 10, 2023Aspirant
I believe you can go into the settings and manually update your router by having it search for the update.
