boofrmb
Jan 08, 2025Aspirant
MR6500 pro interfering with digital tv
Hi All. Just seeing if anyone else is having an issue or knows how I can eliminate the problem. The MR6500 pro is about 15m away from the tv, but continues to wash the digital picture out, notice it...
Jan 08, 2025Guru - Experienced User
Is the tv running over a hardwired connection or wireless?
What happens if you hardwire it in?
Is it connected to the 2.4ghz or the 5ghz currently?
boofrmb
This is interfering with the free to air TV channels,the unit is not connected to the TV, and is wifi around the house for only phones, ipads etc.
Not using it to stream any TV channels.
- plemansJan 09, 2025Guru - Experienced User
they use different wavelengths. did you try a different antenna on the tv?
