Klaus4-1
Oct 16, 2024Aspirant
MR6500 slow downlad
Hi! I have a few questions about this router/modem is ths the last firmware or is there any new one cause it doesnot update by it self and are there diffrences between US and Europe 5G standars? ...
Klaus4-1
Oct 22, 2024Aspirant
how can I open european bands on this devices?
Thanks
Klaus
rcpax
Oct 23, 2024Luminary
Klaus4-1 wrote:how can I open european bands on this devices?
You can't. If your European carrier happens to have the same LTE and 5G bands that are also supported by the MR6500, then the MR6500 will only use those bands. There is no way to "open" other bands. You have to buy an unlocked device like the MR6150 or MR6550 if you want wide compatibility for your hotspot.
