DBM1's avatar
DBM1
Follower
Oct 01, 2022
MR6500 Speed Slow When Connected via Ethernet
I have a MR6500 in ethernet mode connected to my LAN router.  I have the battery taken out, which is required to deactivate WiFi and activate ethernet mode, which seems to be working fine.  Expect the download and upload speeds, are slower when I am in ethernet mode.  When I leave the battery in and the WiFi is on and the ethernet cable is still connected to my router.  The download and upload speeds are 10Xs faster.  I am connected to my LAN router in both cases, not the MAR6500.  We don't have great internet service where I am at and I need a router to connect my cameras & security system.
So you might be asking, so if I am getting 10Xs the download speed and upload with the ethernet still connected and WiFi on, why don't I just stick with that?  Well I did and my ethernet connection was either going to sleep or some sort of conflict that was dropping the ethernet connection on the router after a day or so.  The only way I could fix it was to unplug the ethernet cable and plug it back into the router and then it would start working again.  I was told by a support rep that I shouldn't have my WiFi on if I am using the ethernet port.  They stated that was why I my ethernet connection was dropping.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi DBM1,
    Are you still experiencing this?
    Please provide the device SKU (e.g. MR6500-1A1NAS).
    What is the model number of your WiFi router?
    Did you setup the MR6500 into IP Passthrough mode?
    Blanca
    Community Team
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please capture a model.json file and send PM to me.
    - Logon to the webui (http://192.168.1.1 ) as an administrator
    - Navigate to URL http://192.168.1.1/model.json via the same browser window
    - Capture the results (by selecting all + copy) and send it back
    Also provide the router brand and model. We will check whether we can reproduce.
    Thanks
    John
