PCFreckle
Aug 23, 2023Follower
MR6500 Unlocked - Firmware Update?
Hi, Couple questions....I just purchased an unlocked version of the MR6500. How can I make sure the firmware is up to date? (Is there a non-AT&T branded firmware that can be loaded on it?) ...
hassanizhar
Aug 24, 2023Tutor
To ensure your MR6500 router's firmware is up to date, follow these steps:
Access Router Settings: Connect to your router's web interface via a web browser using its IP address. Log in with admin credentials.
Firmware Update: Look for a "Firmware Update" or "Software Update" section. Check for updates and follow prompts to install the latest version if available.
Regarding the missing 6GHz option, it's possible:
Region Restrictions: Certain regions may restrict 6GHz usage. Check if your router is set to the correct region.
Device Compatibility: Ensure your devices support 6GHz. If not, the router might not show the option.
Firmware Issue: Outdated or incompatible firmware could cause this. Ensure you're running the latest firmware for full feature support.
Router Limitations: Some routers might not support all frequency bands simultaneously. Check the router's specifications.
For alternate firmware, contact the manufacturer's support to inquire about non-AT&T versions. Be cautious with third-party firmware as it could void warranties or cause issues.
