BostonSailor
Sep 02, 2024Aspirant
MR6500 unstable WiFi and signal drops
I've started using this hotspot in an always-on remote application. After a week or so, the unit fails to attach new Wi-Fi devices and has very poor or no Internet access. Rebooting fixes everything, ...
JBish
Until att releases the updates they are not available... I would suggest moving hotspot to a better signal and trying to update the firmware then...
- BostonSailorSep 02, 2024AspirantJBish, I appreciate your help. (1) If you search this community for this issue you will see many posts requesting a json config file so Netgear can provide the right update file. (2) I have the external antenna and getting excellent signal strength.
- plemansSep 02, 2024Guru - Experienced User
the hotspot is 24/7 powered?
Do you have the battery removed?
Have you set the wifi to high powered mode?
Tried setting it up as passthrough and connect a dedicated router to it?
- BostonSailorSep 02, 2024Aspirant24/7: yes
Battery removed: yes
Wifi to high power mode: yes
Pass through router: not yet. I'll try that
- JBishSep 02, 2024AspirantWhat that means usually is they look at logs to try to determine what is causing it and if it's firmware related, it will be fixed in an ota, not that you will get a file to flash.
