BostonSailor
Sep 02, 2024Aspirant
MR6500 unstable WiFi and signal drops
I've started using this hotspot in an always-on remote application. After a week or so, the unit fails to attach new Wi-Fi devices and has very poor or no Internet access. Rebooting fixes everything, ...
BostonSailor
JBish, I appreciate your help. (1) If you search this community for this issue you will see many posts requesting a json config file so Netgear can provide the right update file. (2) I have the external antenna and getting excellent signal strength.
Sep 02, 2024Guru - Experienced User
the hotspot is 24/7 powered?
Do you have the battery removed?
Have you set the wifi to high powered mode?
Tried setting it up as passthrough and connect a dedicated router to it?
