BostonSailor
Sep 02, 2024Aspirant
MR6500 unstable WiFi and signal drops
I've started using this hotspot in an always-on remote application. After a week or so, the unit fails to attach new Wi-Fi devices and has very poor or no Internet access. Rebooting fixes everything, ...
BostonSailor
JBish, I appreciate your help. (1) If you search this community for this issue you will see many posts requesting a json config file so Netgear can provide the right update file. (2) I have the external antenna and getting excellent signal strength.
JBish
Sep 03, 2024Aspirant
What that means usually is they look at logs to try to determine what is causing it and if it's firmware related, it will be fixed in an ota, not that you will get a file to flash.
