Gramp
Sep 26, 2023Aspirant
Mr6500 where do I find admin password
- Sep 26, 2023
There's a small hole under the cover in a slot on the connector side of the device. It will say reset near it. Use a wire probe (straightened paper clip).
Push the reset button in the hole for 10 seconds with the battery attached and charged. That should initiate a factory reset.
