Gramp
Sep 26, 2023Aspirant
Mr6500 where do I find admin password
- Sep 26, 2023
There's a small hole under the cover in a slot on the connector side of the device. It will say reset near it. Use a wire probe (straightened paper clip).
Push the reset button in the hole for 10 seconds with the battery attached and charged. That should initiate a factory reset.
Gramp
I’m currently locked out on the iPad accessing m6. Because of the password issue. Do you know how to do the factory reset from the device it self?
JT240Z
Sep 26, 2023Luminary
