Tangilar72's avatar
Tangilar72
Follower
Sep 01, 2023
Mr6500
How do u find security protocol on the router
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    That page will also have any software, firmware and drivers for your device, if they exist.
    Check the section in the manual Change WiFi encryption settings
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
