TEZ213's avatar
TEZ213
Follower
Jul 01, 2024
MR6500
When my Nighthawk M6 Pro is A/C powered with the battery installed, all options for Internet access work really well for both the unit itself and the EX6100 extender options.
BUT, when I remove the battery from the Nighthawk, both EXT 2 & EXT 5 options will connect but won't allow internet connection.
Cannot understand why the battery makes so much difference.
Any suggestions appreciated.
No RepliesBe the first to reply
