bobpuk1982
Dec 12, 2024Aspirant
mr6550 cannot dual band
dual band worked until yesterday (2.4+6), now only 1 band work, 2.4/5/6 all work if i select only use 1 band. if i choose 2.4+5 or 2.4+6, only 1 band will work, the one band that was last set to work...
bobpuk1982
tried reboot, try both battery and wired power, tried factory reset twice
Dec 12, 2024Guru - Experienced User
Is it still within warranty? If so, I'd contact support
