Joekapala3's avatar
Joekapala3
Follower
Mar 29, 2025
MR6550 Mobile App
Mobile App setup. Where is the admin password
  • The MR6550 default admin username is admin and the default admin password is printed on the device label (inside the battery compartment). On many models the default is just password. If that doesn’t work, do a factory reset to restore the defaults, then log in and set a new password.
  • if left on default, it should be on the label at the back of the device. Otherwise, it's whatever you changed it to be.
