N1KFK
Apr 18, 2025Tutor
MR6550. no 5G mmWave ability to receive on Nighthawk M6 PRO 6550 unlocked Verizon
Hello. I am getting no 5G mmWave Frequencies to receive on Nighthawk M6 PRO 6550 unlocked Verizon. Firmware is up to date and the Verizon Plan does include UW support. I have a tower that is liter...
jamestea455
Apr 18, 2025Aspirant
That's definitely frustrating, especially with a UW-supported plan and tower so close. Sounds like everything should line up might be worth double-checking with Verizon if the IMEI is fully provisioned for mmWave on their network, even though the device is compatible.
- N1KFKApr 18, 2025Tutor
I called Verizon on this and they stated the IMEI is fully provisioned for mmWave on their networki so I have to rely on what rep told me.
well after talking with tech support they are sending me another Sim card so I will let everyone knows what happens. Thanks
