N1KFK
Apr 18, 2025Tutor
MR6550. no 5G mmWave ability to receive on Nighthawk M6 PRO 6550 unlocked Verizon
Hello. I am getting no 5G mmWave Frequencies to receive on Nighthawk M6 PRO 6550 unlocked Verizon. Firmware is up to date and the Verizon Plan does include UW support. I have a tower that is liter...
jamestea455
Apr 18, 2025Aspirant
That's definitely frustrating, especially with a UW-supported plan and tower so close. Sounds like everything should line up might be worth double-checking with Verizon if the IMEI is fully provisioned for mmWave on their network, even though the device is compatible.
N1KFK
Apr 18, 2025Tutor
well after talking with tech support they are sending me another Sim card so I will let everyone knows what happens. Thanks
