buffalo3098234's avatar
Apr 24, 2024
MR6550 Won't Connect to Verizon 5G UW
JohnPeng
Just purchased a MR6550 solely for the 5G connection to Verizon. I am unable to get the MR6550 to connect to the Verizon 5G network (no 4G+, 5G, or 5G UW), despite being in a Verizon 5G coverage area, having the MR6550 on a Verizon Hotspot plan w/ 5G enabled, and calling Verizon who says there are no issues on their side and everything is provisioned correctly. The MR6550 is able to connect and operate on the Verizon 4G LTE network just fine. MR6550 is running firmware NTGX65_12.01.47.00 and PRI 04.11
Any ideas?
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    buffalo3098234 wrote:
    JohnPeng
    Any ideas?
    Thanks for reaching out to me. We are looking for the customers who have the similar issue. Could you please let me know your device IMEI, I can help to upgrade your device to our latest release and see whether the issue can be resolved. If not, I would like to work with you find the root cause.
    John
  • Were there any updates or resolutions? I have the same issue.
    • buffalo3098234's avatar
      buffalo3098234
      No real resolution. Eventually I chalked it up to the Verizon 5G UW signal just not being present at the location (despite their online coverage map stating otherwise).
