RobotPirate's avatar
RobotPirate
My ATT Nighthawk M1 reboots when running plugged in without battery, can this be fixed?
It works fine as long as the battery is in the Mr1100 Nighthawk but when battery is out, the device reboots constantly
I have an Anker 3.0 upgraded  charger but this still happens
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please make sure your device is on the latest release. Using 5V/2A PA should be enough to support no battery operations.
    Could you please help to captuer a model.json file following the stpes below and send the private message to me?
    - Logon to the webui (http://192.168.1.1 ) as an administrator
    - Navigate to URL http://192.168.1.1/model.json via the same browser window
    - Capture the results (by selecting all + copy) and send it back
    Thanks
