RobotPirate
Jun 17, 2021Aspirant
My new Nighthawk M1 hot spot sometimes gets in a loop with "netgear" screen and will not start up
Just got this earlier this week My new Nighthawk M1 hot spot sometimes gets in a loop with "netgear" screen and will not start up Also sometimes when it is cold it keeps reboting, what do I d...
JohnPeng
Jun 21, 2021NETGEAR Expert
Please advise whether your device SKU is MR1100-100NAS. If so, please advise the FW verison and PRI version on the device.
What is the carrier you are using with M1?
Thanks
- RobotPirateJun 21, 2021Aspirant
My device is the MR1100-2A1NAS
Firmware Version NTG9X50C_12.06.21.00
We use ATT as a carrier
The device is working now but sometime when plugged in using no battery, it gets in a loop, shows NETGEAR on screen, then the ATT LOGO, then repeats 4-5 times and I have to unplug device to restart the cycle
Also it restarts sometimes when I click "connect" on my PC, it will instantly reboot
- JohnPengJun 21, 2021NETGEAR Expert
AT&T just released a new update with FW version 12.06.39.00. Please upgrade to the latest version and see whether the issue goes away.
If you use a device heavily, better to insert battery or use a QC PA when not using battery.
It is a typical sign that PA can't provide enough power when using no battery and clicking Connect button results in device reboot.
Thanks
John
- RobotPirateJun 21, 2021AspirantI’m bought an Anker fast charge 3.0 18W, is that good? Here it is below
https://www.amazon.com/gp/aw/d/B077HFFLMS/ref=ppx_yo_mob_b_track_package_o0_img?ie=UTF8&psc=1
Can the Nighthawk be used without battery plugged in safely?
