RobotPirate
Jun 17, 2021Aspirant
My new Nighthawk M1 hot spot sometimes gets in a loop with "netgear" screen and will not start up
Just got this earlier this week My new Nighthawk M1 hot spot sometimes gets in a loop with "netgear" screen and will not start up Also sometimes when it is cold it keeps reboting, what do I d...
JohnPeng
Jun 21, 2021NETGEAR Expert
Please advise whether your device SKU is MR1100-100NAS. If so, please advise the FW verison and PRI version on the device.
What is the carrier you are using with M1?
Thanks
RobotPirate
Jun 21, 2021Aspirant
My device is the MR1100-2A1NAS
Firmware Version NTG9X50C_12.06.21.00
We use ATT as a carrier
The device is working now but sometime when plugged in using no battery, it gets in a loop, shows NETGEAR on screen, then the ATT LOGO, then repeats 4-5 times and I have to unplug device to restart the cycle
Also it restarts sometimes when I click "connect" on my PC, it will instantly reboot
- JohnPengJun 21, 2021NETGEAR Expert
AT&T just released a new update with FW version 12.06.39.00. Please upgrade to the latest version and see whether the issue goes away.
If you use a device heavily, better to insert battery or use a QC PA when not using battery.
It is a typical sign that PA can't provide enough power when using no battery and clicking Connect button results in device reboot.
Thanks
John
- RobotPirateJun 21, 2021AspirantI’m bought an Anker fast charge 3.0 18W, is that good? Here it is below
https://www.amazon.com/gp/aw/d/B077HFFLMS/ref=ppx_yo_mob_b_track_package_o0_img?ie=UTF8&psc=1
Can the Nighthawk be used without battery plugged in safely?- JohnPengJun 21, 2021NETGEAR Expert
This charger looks good.
The M1 supports no battery operations, which reduce the risk due to battey overheated. It would be safer to use M1 without battery if you plan to keep it connected 7/24.
Thanks
John
