dax29
Nov 12, 2021Follower
Naming attached devices
Hi I have a Nighthawk M1 and I'm wanting to rename the various devices that are connected, is there a way to do this
Cheers Dax
That's a relatively specialist bit of kit, so I have no idea if the standard router move works. But when I want to do that sort of thing I either go into the browser graphical user interface (GUI) or the desktop genie.
I find they are much better than faffing around with an app on a mobile device.
You might get more help in the section for your hardware.
Mobile Routers, Hotspots & Modems - JohnPengNETGEAR Expert
I don't think M1 support renaming client names.
Thanks
