sripley12
Dec 06, 2023Tutor
NBK752 (AX4200) not failing over to 5G
Hi folks Got the above set up as broadband (Ethernet) set as the primary with mobile 5G as the backup in the event of primary internet failing. The problem is it’s not failing over. When you ...
CrimpOn
Dec 06, 2023Guru - Experienced User
I would start by double checking that Failover is set correctly as described on page 24 of the user manual:
https://www.downloads.netgear.com/files/GDC/NBK752/NBK752_UM_EN.pdf
sripley12 wrote:
Power cycle the router and everything springs into life.
It is not clear (to me) what this means:
- Power cycle while the ISP connection is off-line, and the router wakes up and switches to LTE automatically?
- or...???
