sripley12
Dec 06, 2023Tutor
NBK752 (AX4200) not failing over to 5G
Hi folks Got the above set up as broadband (Ethernet) set as the primary with mobile 5G as the backup in the event of primary internet failing. The problem is it’s not failing over. When you ...
sripley12
Dec 06, 2023Tutor
Hey thanks - yep all the failover settings are correct.
I mean if you power cycle router whilst its in the state of thinking its connected to the mobile network but obviously isn't it connect to the mobile network and works...
- Sally20_GODec 06, 2023Tutor
mine is also doing the same.
- sripley12Dec 06, 2023Tutor
Ah - interesting.. Oddly I am sure it worked on the day I set up a month or so ago - but the internet failed yesterday and nothing... I've logged a ticket - I'll keep you posted on what I get back.
- CrimpOnDec 06, 2023Guru - Experienced User
It will probably be important to identify the mobile carrier when creating the support ticket.
- sripley12Dec 09, 2023TutorDone some more testing and figured it out (although I don’t understand why).To replicate a failure from my ISP had been powering off the fibre modem - this does not result in the Orbi failing over to the mobile network.Disconnecting the fibre from the modem and the Orbi fails over perfectly. Same result if removing the Ethernet cable from the WAN port on the Orbi.I get there must be some residual connectivity / routing when the modem is powered off but still connected to the Orbi?!?ThanksSimon
