sripley12's avatar
Dec 06, 2023
NBK752 (AX4200) not failing over to 5G
Hi folks   Got the above set up as broadband (Ethernet) set as the primary with mobile 5G as the backup in the event of primary internet failing.   The problem is it’s not failing over. When you ...
