sripley12
Dec 06, 2023Tutor
NBK752 (AX4200) not failing over to 5G
Hi folks Got the above set up as broadband (Ethernet) set as the primary with mobile 5G as the backup in the event of primary internet failing. The problem is it’s not failing over. When you ...
Sally20_GO
Dec 06, 2023Tutor
mine is also doing the same.
sripley12
Dec 06, 2023Tutor
Ah - interesting.. Oddly I am sure it worked on the day I set up a month or so ago - but the internet failed yesterday and nothing... I've logged a ticket - I'll keep you posted on what I get back.
- CrimpOnDec 06, 2023Guru - Experienced User
It will probably be important to identify the mobile carrier when creating the support ticket.
