Dragonboy1
Apr 13, 2023Aspirant
neatgear m6 over heating
dose anyone having over heating issues with the m6 this my second one its hitting 62c with a fan on it and it very slow speed and just not very good
Apr 14, 2023Guru - Experienced User
I've got the MR6110 and no issues with overheating.
Are you running it in performance mode?
Are you using it with the power plugged into it and the battery in it? or battery removed?
Dragonboy1
Apr 14, 2023Aspirant
yeah plig in no battery
- plemansApr 14, 2023Guru - Experienced User
Do you have both wifi bands enabled or only one?
- Dragonboy1Apr 14, 2023Aspirantyeah I got both
- plemansApr 15, 2023Guru - Experienced User
What happens if you disable the 2.4ghz band?
