Riti
Aug 10, 2021Follower
need a help to configure my router.
Hi I've purchased an AX1800 WiFi 6 Router. It will only be used in Wired (Ethernet cable) mode. Unfortunately I cannot configure it as it asks for a username and password that has obviously not be ...
michaelkenward
Aug 11, 2021Guru - Experienced User
Riti wrote:I've purchased an AX1800 WiFi 6 Router.
Unless it is an MR5200, you probably won't find much useful advice in this bit of the community, which is for Mobile Routers, Hotspots & Modems.
If it is something like the RAX20, then try here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Look at the label on the thing for the model number.
