Latte12
May 13, 2021Follower
Need a netgear home wifi streaming equipment.
Hi, I would like some recommendations for streaming wifi using netgear products. 2 streaming TVs, 2 phones; Need modem, router and 2 satelite points. Would appreciate some recommendations. internet c...
michaelkenward
May 14, 2021Guru - Experienced User
I have no idea what "satellite points" are. But I very much doubt if you need anything from Netgeatr's range of "Mobile Routers, Hotspots & Modems".
That's what this section is for.
Your request is so general, that it is all but impossible to provide a useful answer. Start with your Internet service provider to see what sort of modem you need.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
