TrayalWalker
Oct 12, 2019Aspirant
Need Antenna that fits
I just purchased and received the Nighthawk MR1100. I also purchased and received two T9 little rubber antenna from Eightwood which do not fit the slots on the nighthawk. Which antenna fits the slots?...
Oct 12, 2019Guru - Experienced User
Here's a thread from a prior discussion on this.
- TrayalWalkerOct 12, 2019AspirantI don’t think I can attach that antenna model to the inside of my car, or hang it from a mile post or rest stop sign when I’m traveling.
I’m being funny, But I was hoping for an ideal attends that is inserted into the slots provided on the hotspot so that I could take it on the road and maybe sit at a rest stop to get on the internet without having a really bad reception.
Any other ideas?- TrayalWalkerOct 12, 2019Aspirantforgive autocorrect. should be antenna
- plemansOct 12, 2019Guru - Experienced User
here's a website that shows compatible devices. Their prices are a bit high but you can find some of the same devices/antenna's they list on amazon.
