KawaNinja's avatar
KawaNinja
Follower
Jul 27, 2023
Need command line or WEB browser reset AC800S modem
Hi there!
My AC800S sometimes disconnects from 3G/4G network and takes a restart to re-connect.
My home alarm system is connected to the router that's why it is kind of mission critical to have constant connectivity.
I need a way to restart the router programmatically via a script or a macro.
Is there a RESTART command that I can send via HTTP or any CLI ?
Thanks
PS: The Mobile Netgear Android app has a POWER button, but the app is not stable on my old Android 6.0 phone to be able to develop a macro to control it, sometimes it loops on login screen. The router is not compatible with the new NightHawk app.
No RepliesBe the first to reply
