chesed
May 09, 2024Aspirant
Need Help Finding a Battery
Hello, I have been having an impossible time trying to locate a battery for my OLD MR5000. Here are the specs on my old (still working) battery... Model No: W-10a Rating 3.85V 19.78Wh Min Capaci...
chesed
Just a further update. The Battery I currently have is 'bloated' and I don't know haw many days it has left. If it goes Kapoot then my Netgear MR 5000 becomes worthless. I really need help on this one.
Thanks.
- JT240ZMay 10, 2024Luminary
Try doing a search. Found this one on Amazon.
- chesedMay 10, 2024Aspirant
Hi, thanks, if the 1ICP number and P/N number is different will it still work?
I meant to say Hi, thanks, Since the 1ICP number and P/N number are different will that battery still work?"
Ok, I went ahead and purchased the w-10a version of this battery because someone else recommended it as a compatible replacement, sooo, we’ll see 👁 👁.
