Night-Owl
May 16, 2021Tutor
Need help with some MR5200 Features
Hi, I was hoping someone could help me as i've tried 3 times to speak to Neargear support through live chat and just keep getting told they are not trained on the product, or i'm given incorrect ...
- May 20, 2021
Hi Night-Owl ,
1. Always on WiFi - When plugged into a power source, your WiFi will never go into standby mode.
2. Data Offloading - This feature allows you to offload your data connection to something hanging off the ethernet port(Fixed line connection). If you unplug the ethernet cable of fixed line modem goes down then it will revert back to using the mobile connection. This feature also allows you to offload data to a WiFi connection when you are travelling(i.e hotel WiFi).
3. IP Passthrough - This is bridge mode
4. WiFi Standby - This setting allows you to configure when to turn your WiFi off if nothing is connected. Helps to preserve battery life if not in use. WiFi will not go into standby if plugged into a power source. Press the power button to wake it up if it does go into standby.
5. Ethernet Standby - 2 minutes is the default shut off if there is no activity. Press the power button to wake it up if it goes into standby. Also to preserve battery life. Ethernet will not go into standby if plugged into a power source.
ArodiD
ArodiD
May 20, 2021NETGEAR Expert
Hi Night-Owl ,
ArodiD
- Night-OwlMay 20, 2021Tutor
Finally, someone who knows what they are talking about from Netgear!!! Thank you!!!
I've been on the live chat 3 times now and no one has been able to help me, just guessing, telling lies and even leaving the chat pretending the line went dead because they don't know.
So I just want to confirm i'm understanding this correctly with the "Data Offloading" feature as it it confusing me a little....
Am I right in thinking this works opposite to the way the device normally works? It will take the WAN connection from whatever network the ethernet is connected to (using the networks DHCP server, you cannot assign an IP?) and use that rather than the LTE connection?
But as soon as you unplug the WiFi it switches to LTE again? Thus saving your LTE data and allowing all your devices connected to the MiFi to tether off the network it's plugged into/or Offloading by from another WiFi network?
Thanks for your help.
- ArodiDMay 21, 2021NETGEAR Expert
Hi Night-Owl ,
Yes, you are right. The LAN port becomes a WAN port when Data Offloading to Ethernet is enabled. It will only use 5G or 4G connection if Ethernet WAN is down.
As soon as you unplug the Ethernet Cable(if offloading via Ethernet) or loses range of WiFi(if offloading via WiFi) it will start using the 5G or 4G connection. If Ethernet cable is plugged in(and fixed connection is up) or if it comes into proximity of WiFi signal(i.e when you come home from travelling) then it will switch back to the fixed connection and your 5G/4G connection will not be in use.
Arodi
