87MikeR
May 03, 2021Initiate
Need MR1100 Nighhawk Mobile Hotspot APN Settings for ATT
In working with ATT on another issue they had me change all the APN settings in my MR1100. Unfortunately no one at ATT seems to know what these settings need to be. I need the correct ATT settings for:
APN Name:
APN:
Authentication:
PDP Type:
PDP Roaming:
Right now I have these set to the following:
APN Name: ATT
APN: Broadband
Authentication: None
PDP Type: IPv4
PDP Roaming: IPv4
It will connect and work with ATT, but it is very slow (2Mbps on average in a speedtest). I found the APN settings I entered on the web and was not very confident they were really optomized so wanted to see what others were using. Thanks.
- Might have better luck in the mobile hotspot forum and not general router forum.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
1 Reply
- plemansGuru - Experienced UserMight have better luck in the mobile hotspot forum and not general router forum.
