cmir2426
Dec 07, 2019Aspirant
Need newest Firmware for DC112A-1Z1MES for Zain Latest FW is 1.0.0.42
I would like to have this firmware to update my dc112a. I currently has firmware V1.0.0.4_1.0.60. When attempting the gui update it keeps failing.
Dec 07, 2019Guru - Experienced User
I don't have this device but you can download the firmware. When you navigate to the firmware upgrade section in the settings, is there a browse option?
Advanced > Administration > Router Update.
Can you download the firmware and then manually install it?
make sure if you download it to extract it as its in a zip format.
https://www.netgear.com/support/product/DC112A.aspx
cmir2426
Thank you for the response, I have tried the gui update but it says firmware is not for this router. I have also done a manual update with the stated fw file and it says invalid.
- plemansDec 07, 2019Guru - Experienced User
did you successfully extract it?
You can't just click on it. You actually need to either use a built in extractor or download one.
It'll error out everytime if its not extracted.
it looks like people running the zain model are having issues.
