Tsprint2
Feb 06, 2019Follower
Need to extend Hotpot to include 2 ethernet ports
I just moved to a place with no options for internet except Verizon 4g with 4 bars. The network speed is not great for much but good enough for browsing internet and email. I have Arlo that requires a...
nanoman
Feb 08, 2019Aspirant
Hi I have the same need. I connected a switch to the EX6120 but no joy. See connection layout. Each of the PoE units is active. I would appreciate any thoughts / comments on how to get this to work. Only the device on port 1 is working.
Thanks,
JSchnee21
Feb 10, 2019Virtuoso
Get the MR1100 and add a small Ethernet switch (Netgear GS105 or GS108) -- piece of cake. Note that the DHCP server in the MR110o only supports 20 devices.
- nanomanFeb 11, 2019Aspirant
Thanks, however your suggestion does not address my issue - I already have a wireless hotspot / router (up to 10 connected devices in my case) that, unfortunately, does not have an ethernet port. I believe this is a common configuration for many hotspots.
So, the idea is to use a WIFI extender (with an ethernet port, e.g. Netgear EX6150, EX6100, etc. ) with a multiport switch to provide connectivity to multiple wired ethernet appliances. It seems like it would work seemingly as wired in early post diagram. This is what I am questing help on.
ASIDE: I am not sure that the MR1100 will work on Straight Talk network (verizon network).
