ddt000
Jun 05, 2021Aspirant
need to repair MIMO Antenna (6000450) by replacing a TS-9 connector
I have a broken TS-9 connector on my MIMO antenna and would like to replace it. But I can't find any technical info on the antenna cabling to ensure I order the correct model. Here's an example...
ddt000
Jun 11, 2021Aspirant
Is this a weird question? I thought it was kinda standard.
JoeDiver
Jun 18, 2021Aspirant
I'm hoping someone will answer this too. It seems like a simple process and the one on the antenna is not very well built. I'd like to make a more solid connection
- michaelkenwardJun 19, 2021Guru - Experienced User
There is nothing "Netgear" about this sort of problem. The same appraoch will apply to anything that has an antenna that needs fixing.
Have you tried a wider search? YouTube has all sorts of "how to mend it" videos.
- ddt000Jun 19, 2021Aspirant
Sorry Mike,
but that's not helpful. I actually put a link to just the sort of resource you mentioned in my original post. And I think I was quite clear that I need to know the cabling Netgear uses on the antenna so that I purchase the correct type of TS-9 connector - they vary in size to accommodate the various sizes of coax cabling.
