Cricket-user
Sep 05, 2021Guide
Neither the Orbi LBR20 or LM1200 AT&T certified.
Having found out that after February 2022 AT&T is shutting off there 3G system I have been looking for a device that Cricket wireless (AT&T) would allow to be activated on a DATA plan. Rather annoyin...
Blanca_O
Sep 17, 2021NETGEAR Employee Retired
Hi Cricket-user
Welcome to NETGEAR Community!
This has been brought up already to the concerned team. After further investigation, it turns out to be a misidentifying the devices case. These devices will work as long as you on the right plan.
We are aware that AT&T will be retiring the 3G network in February 2022. The devices like M1, M5, LAX20, LBR20 and others that support LTE/5G will still work, it will just not fallback to 3G anymore.
Blanca
Community Team
- Cricket-userSep 17, 2021Guide
At&t has a list of acceptible devices for after Feb,22 3G shutdown. The only netgear devices are the M1 (Mr1100), M5 and the Unite mobile hotspots. There is no listing for the models (LAX20, LBR20) you are selling as AT&T certified. So until AT&T modifies their list the IMEI for those device show them as incompatible. It does not matter the plan.
Your concerned team needs to do a bit more homework.
- Blanca_OSep 22, 2021NETGEAR Employee Retired
Hi Cricket-user
The LAX20 and LBR20 modules are certified to work with AT&T but there is no AT&T specific SKUs for these two products and they are both LTE devices not 3G.
Blanca
Community Team
