Kaleicardinez
Mar 09, 2021Follower
Net gear LTE MODEM LM1200
Anyone can help me get this to work with my AT&T sim?
Blanca_O
Apr 08, 2021NETGEAR Employee Retired
Hi Kaleicardinez
Welcome to NETGEAR Community!
What is the error message when you try setting it up?
Kindly check with your ISP if you have the right type of data plan for LM1200.
Please get the correct APN information from your ISP and add it using WebUI.
Blanca
Community Team
JohnPeng
May 03, 2021NETGEAR Expert
The device has been certified with AT&T. Please ask AT&T what type of data plan can be used with the device.
Thanks
John
