Qunna95
Feb 22, 2021Follower
Netgear 4G LTE
Hello everyone, I’ve recently purchased the netgear 4G LTE modem and I’m have trouble with the power light turning green. Here are a few facts and things I’ve tried.
*im using straight sims card
*everything is hooked up
*I’ve Tried changing the APN(may not be doing it correctly) 😭
*The router is blue(connected)
* the router light is blinking green
PLEASE HELP ME
PLEASE HELP ME
You have posted your message in the section of this community given over to Nighthawk WiFi Routers
Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.- Blanca_ONETGEAR Employee Retired
Hi Qunna95
Welcome to NETGEAR Community!
Have you tried factory resetting the device? If not, please do so and let us know if it helps.
Kindly check this link as reference for the list of error conditions if the Power LED bar blinks amber fast and an individual signal strength bar is on or off [page 85 - 86]
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf
Blanca
Community Team
