138shadow
Jun 14, 2020Follower
Netgear 65
I am trying to hook up a Gosund smart plug to use with my Amazon Dot (Alexa) I cannot get it to work. It tells me I need to use it with a 2.4 GHz. On my modem/router the 2.4 GHz light is blinking ...
Jun 14, 2020Guru - Experienced User
blinking usually means traffic is being transmitted. Meaning its working.
Make sure your phone/tablet is on 2.4ghz during setup. With these cheaper IoT device, they need to be on the same wifi as the device being setup.
