francismartens
Aug 20, 2017Aspirant
Netgear 785 - stuck in 'shutting down'
This little device was a gem - always working. Since yesterday, after bringing up the device it immediately goes into 'shutting down' mode I have been looking at the different posts on this subj...
DarrenM
Aug 22, 2017Sr. NETGEAR Moderator
Hello Francismartens
Have you tried a factory reset? If you still can not get the device to boot and it is still under warranty I suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
francismartens
Aug 22, 2017Aspirant
Hi,
Pressing the navigation and power buttion as detailed in
https://kb.netgear.com/25853/How-do-I-reset-my-AirCard-785-to-factory-default-settings
is not helping neither.
Unless there is another way to do a factory reset, I will have to contact support.
Thanks anyway
Francis
