Dimanu4
Apr 06, 2018Follower
Netgear 791L can I power it without battery on AC charger?
Hello. I want to buy Netgear 791L. And I have a question, can I use it without a battery? I want to use it with a charger without a battery.
- JasonNNETGEAR Employee Retired
Hi Dimanu4,
If you refer to the link below. There is a user that confirmed they can use a AC785 without battery and with a AC power connected. I don't see the difference with the 791L
Please let me know when you have tried the AC power. :]
- Jason N
Hi Dimanu4,
I just wanted to check up on you and see if you have tried the AC power.
Please let me know. :]
- Jason N
