akido
Jan 03, 2017Apprentice
Netgear 810 update
Netgear 810 unlocked I often check the device touch screen for a chance to get a new update to resolve the many issues I suffer from,but sadly nothing in the air ,wonder how netgear a networking comp...
- Mar 14, 2017
The release is still on track for Mar 20.
Steve
TeeJay74
Feb 13, 2017Virtuoso
I was asked to patience and they know we are frustrated. QA team is doing their job with update. Release cannot be far that is my conclusion as I try to keep my mood positive.
- Retired_MemberFeb 13, 2017
Some more information: 256QAM is working. A part of QXDM log file:
2017 Feb 11 20:40:32.980 [7C] 0xB126 LTE LL1 PDSCH Demapper Configuration
Version = 23
Serving Cell ID = 207
Sub-frame Number = 8
System Frame Number = 287
PDSCH RNTIl ID = 49809
PDSCH RNTI Type = C-RNTI
Number of Tx Antennas (M) = 2 antennas
Number of Rx Antennas (N) = 2 antennas
Spatial Rank = rank 1
RB Allocation Slot 0 = 0x0000000000000000, 0x000000000000000F
RB Allocation Slot 1 = 0x0000000000000000, 0x000000000000000F
Frequency Selective PMI = Wideband
PMI Index = 2
Transmission Scheme = Closed-loop spatial multiplexing
Port Enabled = Reserved
Transport Block Size Stream 0 = 2664 bits
Modulation Stream 0 = 256QAM
Traffic to Pilot Ratio = 1.414
Trnasport Block Size Stream 1 = 0 bits
Modulation Stream 1 = 256QAM
PB = PB = 0; RhoB/RhoA = 5/4
Carrier Index = PCC
CSI-RS Exist = None
ZP CSI-RS Exist = None
CSI-RS Symbol Skipped = Not SkippedIf necessary, i can send full log. I think this is good news!
- TeeJay74Feb 13, 2017Virtuoso
Absolutely great news! Did you notice +20...33 % boost to downlink performance ? What's your download speed with 256-QAM ? It would be great If you could share your signal values as reference when 256-QAM is enabled.
Some more questions considering 256-QAM. AC810 '4G details" screen has that Quality indicator. It is a percentage value 0 -100 %. What's your quality value ? What is your physical distance to mast when 256-QAM is active ?
