akido
Jan 03, 2017Apprentice
Netgear 810 update
Netgear 810 unlocked I often check the device touch screen for a chance to get a new update to resolve the many issues I suffer from,but sadly nothing in the air ,wonder how netgear a networking comp...
- Mar 14, 2017
The release is still on track for Mar 20.
Steve
Retired_Member
Feb 13, 2017Some more information: 256QAM is working. A part of QXDM log file:
2017 Feb 11 20:40:32.980 [7C] 0xB126 LTE LL1 PDSCH Demapper Configuration
Version = 23
Serving Cell ID = 207
Sub-frame Number = 8
System Frame Number = 287
PDSCH RNTIl ID = 49809
PDSCH RNTI Type = C-RNTI
Number of Tx Antennas (M) = 2 antennas
Number of Rx Antennas (N) = 2 antennas
Spatial Rank = rank 1
RB Allocation Slot 0 = 0x0000000000000000, 0x000000000000000F
RB Allocation Slot 1 = 0x0000000000000000, 0x000000000000000F
Frequency Selective PMI = Wideband
PMI Index = 2
Transmission Scheme = Closed-loop spatial multiplexing
Port Enabled = Reserved
Transport Block Size Stream 0 = 2664 bits
Modulation Stream 0 = 256QAM
Traffic to Pilot Ratio = 1.414
Trnasport Block Size Stream 1 = 0 bits
Modulation Stream 1 = 256QAM
PB = PB = 0; RhoB/RhoA = 5/4
Carrier Index = PCC
CSI-RS Exist = None
ZP CSI-RS Exist = None
CSI-RS Symbol Skipped = Not Skipped
If necessary, i can send full log. I think this is good news!
TeeJay74
Feb 13, 2017Virtuoso
Absolutely great news! Did you notice +20...33 % boost to downlink performance ? What's your download speed with 256-QAM ? It would be great If you could share your signal values as reference when 256-QAM is enabled.
- TeeJay74Feb 13, 2017Virtuoso
Some more questions considering 256-QAM. AC810 '4G details" screen has that Quality indicator. It is a percentage value 0 -100 %. What's your quality value ? What is your physical distance to mast when 256-QAM is active ?
- Retired_MemberFeb 13, 2017
TeeJay74 wrote:Absolutely great news! Did you notice +20...33 % boost to downlink performance ? What's your download speed with 256-QAM ? It would be great If you could share your signal values as reference when 256-QAM is enabled.
Yes, of course, it's a difference between 256QAM and 64QAM.
Signal values:
!GSTATUS:
Current Time: 1025 Mode: ONLINE System mode: LTE PS state: Attached
EMM state: Registered Normal Service
RRC state: RRC Connected
IMS reg state: No SrvPCC:
LTE band: B3
LTE bw: 15 MHz
LTE Rx chan: 1779
LTE Tx chan: 19779
RSSI (dBm): -46.9
RSRP (dBm): -78.8
RSRQ (dB): -10.7
RSSNR (dB): 3
Tx Power (dBm):
LTE Cell ID: 409100
Physical Cell ID: 187
TAC: 17716
OKCQI value is between 12 and 14 with external antennas:
Speed: Download 35 mbps, Upload: 15 mbps.
TeeJay74 wrote:Some more questions considering 256-QAM. AC810 '4G details" screen has that Quality indicator. It is a percentage value 0 -100 %. What's your quality value ? What is your physical distance to mast when 256-QAM is active ?
https://www.dropbox.com/s/4n9fuchrjsjd9cr/CH%20Quality.PNG?dl=0
About physical distance between device and eNodeB i cant answer, because i'm only a simple user :)
Looks like 300 or 400 meters (information about eNodeB from location service xinit.ru).
How is your typical SINR behavior ? Is it stable or any big variation visible ?
TeeJay74 wrote:How is your typical SINR behavior ? Is it stable or any big variation visible ?
It is not stable. It looks like roller coaster :smileytongue: May drop sometimes and grow again.
